r3badboy
New Zealand
06 Rocket 3 & all years parts built R3 & 06 flood
Question is I want to swap roadster rails onto a classic.
A mate gave me his roaster rails (after fitting forward controls) minus the brake peddle & master cylinder.
Can I bolt on the classic master cylinder on the roaster rail & obviously make another brake line??
Am yet to buy a roadster brake peddle too.
You have the ideal Classic brake lines which are a tad longer and in demand by those doing the more common swap and fitting Classic footboards to their Roadsters.
It shouldn't be hard to find a swap and they are common as muck on eBay too just be sure you get one that matches the fittings. Some just extend the stock hard metal Roadster line with rubber brake line to fit the Classic footboards brake system so you may be able to get by just gently putting extra curves in your hard Classic metal and soft rubber brake line to fit the Roadster foot controls.
"Compare and Simplefy" as the meercat says:
Fowlers Triumph in UK is a good info source, but as can be found for many shared parts types between various Rocket III versions the Triumph factory only used a GENERIC image for parts that may not accurately illustrate the specific part but the part number and description will.
BUT using 'Triumph' together with the correct part number and / or description you can search 'Google images' and usually find a photo of the actual part too.
Classic
#PartStockRRPQty
Used
Basket
1M/Cyl & Reservoir Assy
T2025202
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$274.51inc. VAT(ÂŁ150.89)-QuantityMinusPlus
2Connector Set
T2022108
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$26.37inc. VAT(ÂŁ14.50)1QuantityMinusPlus
3Piston Set, Rear Master Cylinder
T2022110
Share this part
1-3IN STOCK$69.49inc. VAT(ÂŁ38.20)1QuantityMinusPlus
4Circlip, M’cyl, Rear
T2020472
Share this part
1-3IN STOCK$2.79inc. VAT(ÂŁ1.54)1QuantityMinusPlus
5Assy, Pushrod
T2025009
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$43.05inc. VAT(ÂŁ23.66)-QuantityMinusPlus
6RESERVOIR SQUARE TANK ASSY
T2024080
Replaces T2023191
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$47.22inc. VAT(ÂŁ25.96)1QuantityMinusPlus
7Reservoir Hose Clip
T2023188
Share this part
IN STOCK$3.56inc. VAT(ÂŁ1.96)2QuantityMinusPlus
8HOSE, RESERVOIR, M/CYL REAR
T2022130
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$34.36inc. VAT(ÂŁ18.89)-QuantityMinusPlus
9Brake Pedal Assy
T2025207
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$187.27inc. VAT(ÂŁ102.94)-QuantityMinusPlus
10Bolt, Shld, M8, Slv Enc
T3331614
Replaces T3331612
Share this part
IN STOCK$10.24inc. VAT(ÂŁ5.63)1QuantityMinusPlus
11Spring, Brake Lever Return
T2020274
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$10.04inc. VAT(ÂŁ5.52)-QuantityMinusPlus
12Pin, Clevis, 8 x 13.7
T3000301
Share this part
1-3IN STOCK$4.37inc. VAT(ÂŁ2.40)1QuantityMinusPlus
13Clip, 8mm, Clevis Pin
T3000302
Share this part
1-3IN STOCK$6.18inc. VAT(ÂŁ3.40)1QuantityMinusPlus
14Rubber, Brake Pedal
T2025001
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$40.34inc. VAT(ÂŁ22.18)-QuantityMinusPlus
15Screw, But/Hd, Skt, M8 x 25
T3335012
Share this part
1-3IN STOCK$8.49inc. VAT(ÂŁ4.67)2QuantityMinusPlus
16Cover, Master Cylinder
T2025103
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$54.06inc. VAT(ÂŁ29.71)-QuantityMinusPlus
17Screw, Tx, Pan/HD, M6 x 16, Slv
T3330334
PLEASE INFORM YOUR CUSTOMER THAT IF THIS BOLT IS TO BE USED AS A FAN TO RAD BOLT, THEY WILL REQUIRE AN ADDITIONAL 1 OFF T3350033 (SPRING WASHER) AND 1 OFF T3550034 (PLAIN WASHER) PER BOLT
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$2.69inc. VAT(ÂŁ1.48)2QuantityMinusPlus
18Locknut, Flanged, M6 x 1.0
T3350003
Share this part
IN STOCK$0.98inc. VAT(ÂŁ0.54)1QuantityMinusPlus
19Cover, Master Cyl Reservoir
T2025102
Share this part
20Heelguard, RH
T2025101
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$58.88inc. VAT(ÂŁ32.36)-QuantityMinusPlus
21Screw, Btn Hd, M8 x 12, Slv
T3331625
Share this part
IN STOCK$1.77inc. VAT(ÂŁ0.97)1QuantityMinusPlus
22WASHER M8 BS4320 FORM B SS
T3550277
Replaces T3550260
Share this part
IN STOCK$1.07inc. VAT(ÂŁ0.59)-QuantityMinusPlus
23Washer, 15.2 x 10 x 1, Plated
T3550229
Share this part
IN STOCK$1.16inc. VAT(ÂŁ0.64)4QuantityMinusPlus
24Bolt, Banjo, M10 x 21
T3250125
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$7.14inc. VAT(ÂŁ3.92)2QuantityMinusPlus
25Brake Line Assy, Hard
T2025204
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$29.71inc. VAT(ÂŁ16.33)-QuantityMinusPlus
26Guide, Brake Hose
T2020269
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$7.25inc. VAT(ÂŁ3.98)-QuantityMinusPlus
27Adaptor, In-Line, Brake Switch
T2025005
Share this part
NOT IN STOCKAdd to Basketto Order(see FAQ)$23.16inc. VAT(ÂŁ12.73)-QuantityMinusPlus
28Screw, Tx, Pan/HD, M6 x 16, Slv
T3330334
Share this part
Roadster
#PartStockRRPQty
Used
Basket
T2025202
Share this part
2Connector Set
T2022108
Share this part
T2022110
Share this part
T2020472
Share this part
5Assy, Pushrod
T2025009
Share this part
T2024080
Replaces T2023191
Share this part
T2023188
Share this part
T2022130
Share this part
9Brake Pedal Assy
T2025207
Share this part
T3331614
Replaces T3331612
Share this part
T2020274
Share this part
T3000301
Share this part
T3000302
Share this part
T2025001
Share this part
T3335012
Share this part
T2025103
Share this part
T3330334
Share this part
T3350003
Share this part
T2025102
Share this part
20Heelguard, RH
T2025101
Share this part
T3331625
Share this part
T3550277
Replaces T3550260
Share this part
T3550229
Share this part
T3250125
Share this part
T2025204
Share this part
26Guide, Brake Hose
T2020269
Share this part
T2025005
Share this part
T3330334
Share this part
I have since edited the first reply with more useful info re searching for correct parts.
Basically all I need to know if the classic master cylinder bolts onto the roadster foot rail...I know part numbers are different & I cant remember if the spacing is the same on the bolt on points.
I'd rather wait till I got the extra bits than pull things off & have down time on the bike....although I have 2 others to ride.
No the Classic and roadster master cylinders are not interchangeable The brake pedal set up is different as well.
