Spent the last few days getting on with the work on the bike. Found some nasty things and then some good stuff happened.
1. Wasn't able to get away with just removing the cam sprockets to fit the non tensioning guide and had to take the cams out. Fitting the new guide wasn`t much of a problem after they were removed. Getting the engine timed up again went okay with the cam alignment tool and all the marks were easy to see.
2. After the cams were out I took a look at things, lots and lots of heavy scoring on the cam ladder, the cams themselves and the inside of the head where the cams run. I presume this is due to debris ending up there from when the output shaft bearing went and the gear on it got the edges of the teeth chipped off. The scoring was most severe above the cylinder at the rear of the engine, not as bad in the middle and much lighter above the front cylinder. Its far past the feel it with a fingernail stage its more like can feel the scores with your elbow stage! A bit alarmed by this I cut open the oil filter to have a look inside, thankfully there was no fresh metal in it so there doesnt appear to be any ongoing loss of material..............for the moment
3. I put it back together for now with the new cam chain, guides and tensioner spring. Then I managed to find a place that was clearing out a stash of triumph parts and got myself a brand new and never been fitted bare head from their old stock. It may be an early one as it is silver. When the scored up one starts giving problems I can put the new head on with a fancy set of cams for a nice upgrade. Hopefully I can reuse the valves and springs etc from the one thats currently on the bike and will just need to buy stem seals and a head gasket for it.......... Theres no point putting my scored cams in a shiny new head or it will damage it too.
4. Next job was onto the clutch which had been slipping so I was only able to ride the bike gently to try and preserve what was left of it till getting a chance to replace it. The friction plates were quite badly burnt and the steel plates were blackened on the surface with sexy purple/blue inner teeth on them. Things must have been getting toasty in there. Measuring the steel plates for warpage showed one of them to have close to 1mm warp in it and three more to be warped to around 0.6mm. The rest were within tolerance but I managed to get a new full set of replacements for about a third of what they should have cost from another place having a clearout. So new steel plates, new ebc friction plates and a set of stiffer ebc springs should have the clutch as good as new.
5. On to the fun stuff, got the radiator fan and shroud cut down and transferred over to the new TTS radiator, oil cooler bolted on, and a nice new set of samco silicone hoses and clamps attached. It will be a while yet before the supercharger goes on as I want to have the use of the bike for the spring and summer first so it made sense to do some of the stuff now while things were apart. All the holes lined up nicely although the shroud did need to be spaced off the radiator by 2mm with washers to stop it pressing into the fins. A few of the rubber flaps on the back of the shroud were torn on their attachment points but a little drop of super glue and they are secure and ready to flap again.
6. Then I plumbed in the boost/vacuum gauge to the spare vacuum port on the centre throttle body, routed the hose nicely and cable tied the gauge in position temporarily until the bracket I was having made is ready.
7. Next job is to open up the tank and replace the fuel pump with a walbro gss342 that seems to be a popular upgrade, and to try and adjust the fuel sender to get a reading that somewhat resembles how much fuel is actually in the tank. I found some good instructions here: Triumph Rocket III Community
Thats all for now, will hopefully have the bike up and running again by the weekend.
