That sounds great, but what's a 10 minute tune?
If it's what I think he's refering too, (I've always heard it called the 12 min tune) it's where you "relearn" the ECU parameters.
I'll give you the process for the tune I'm thinking of, if he has something else in mind he can brief you when he gets back.
1) Start the Bike and allow it to run until the radiator fan turns on for the 1st time.
2) Once the fan starts, do not touch the throttle.
3) Allow the the bike to stand, running and untouched from this point for at least 12 minutes. (the fan may cycle multiple times during the process, this is normal)
4) At the end of the 12 minutes turn off the bike and allow it to stand, untouched, to cool down. (this isn't really part of the procedure, I do it just to be sure since the ECU is awake and powered all the time.)
This should reset the ECM to the bikes current operating parameters and store the information for how it will operate it's sytems next time it's started. Since full operating temperature is the optimum running conditions for an engine, doing this allows it to know whats "normal" and adjust for other conditions using these settings as a baseline.
This tune is always good to try 1st if she isn't running right all of a sudden. The ECU is just a computer and program code lines sometimes just don't load. Just like if you shut off your computer wrong or something similar .... It's a snapshot with "normal" readings made available to it for sampling.
