grampi
Three weeks ago I bought a 2013 Roadster that I'm having an issue with. The bike has ram air, and TORS exhaust with a crossover pipe (the one from Australia). The bike also has been professionally dyno tuned. Shortly after buying the bike I noticed it was doing two things. Originally I thought they were separate issues, but now I believe they may be related. When accelerating slowly, the engine sputters and misses (and sometimes even backfires) with the throttle position just above idle. It's most noticeable when shifting, but yesterday I was able to hold the throttle position right at the spot it occurs for a good 2-3 seconds and the engine was missing like crazy, and it backfired. The other thing it's doing is sputtering, pretty much in any gear from 2nd on up, when holding the throttle in a steady position with the RPMs between about 2500 and 3000. The engine seems to run fine at idle, and at any other throttle position other than just above idle. WOT it runs fine. The person that tuned it made a new map as he saw an area of the old one that was a little lean, but the new map didn't fix the problem. Any idea what could be causing this? Thanks.
