REGULATOR
Turbocharged
heres the deal,
I reflashed my ECU because I sorta thought I should do that from time to time...
used tuneboy many times, never a problem, reloaded the same tune, packed up the lap top and headed out for Daytona... funny thing is teh check engine light was one when I fired up and pulled out..
My thought at the time was that after a few cycles it woudl go out ( again I heard of the ligth comming on after messing with stuff)
well it never went out, except for an ocaisional weak idle it ran like a champ all weekend
now that I'm home, I get teh kids to bed, crack a cold one, reflash again, also open up tuneboy to reset idle, do force adapt etc
well when I fired up the engine the check engine light was still on..
I looked on the actual dashboard tuneboy screen to check errors, and it says check engine on, but where do I read what the error is?
I'm running NEW unifilters, my MAF sensor is in its own seperate filter thing, I checked O2 sensor because I do not have one connected because I'm running a predator pipe....
and appropriate predator tune...
what am I missing? and how do I determine whats triggering the check engine light with tuneboy?
