Discrepensies between 4th and 5th gear pull. Very pleased with the results.
Mods are RU1770 K & N's, secondaries removed, Matty's tune for a base using his timing, and Jardine full system for Roadster.(2010)
4th gear was prefderred gear for tuning.
Prior to the Jardines, I had TOR's with the staintune crossover. Bike showed max power at 143.02 and max torque of 148.95
With the larger ID Jardine full system, huge improvement.
4th gear final results are 151.88 RWHP and 155.14 torque
5th gear final results are 155.04 RWHP and 159.99 torque
If anyone interested in the sound of the new system, you can see the dyno run on the triumph rat site.
It's under rides and events, Houston NE ride site. You'll see the Roadster on the ddyno and you can click on it to see and hear the run. They're loud in a good way.
On ride home, you could really feel the difference with the extra torque.
Going back to the dyno next saturday and try to fix the A/F discrepencies between 4th and 5th gear. I'll post the dyno sheets after I scan them.
later
Thanks. Great numbers and great videos. The Jardines look really good on the bike. I viewed the first vid over and over because it gives a good idea of how it sounds.
Pig9R,
Brian,
The **** moderator Diego is GONE now.
The new moderator Lee, is an old hand and A LOT better.
He's known as Massive on the .com site.
Don't know if he's on here or not,
but I'm sure if you'd ask Lee, he'd welcome you back.
He seems like a good guy for sure,
I even invited him to the RAA.
Take care buddy,
skip
I'm using Tuneboy. My tuner says the tuneECU is better to analize. Something about putting on excel spreadsheets for comparison or something. Anyway, ahe's sucking out the tune in that format and try to get see what's happening between 4th and 5t gear.
I'llk post up the new numbers next week.
Pig9R,
Brian,
Take care buddy,
skip
