Hi folks i just took my rocket out for its first ride its done 1750 mls and has just been serviced at a Triumph dealer .The first thing i noticed was the amount of dec pop and it does it in all modes , so my question is i take it this is normal !, its been 3 years since i tested a rocket 3 so cant remember if this was a thing or not .
I have the 3R. It should not be decel popping with stock exhaust. Now a little burbling is normal, but not PoP, PoP, Pop! Among other suggestions you may hear I'd look at the possibility of an exhaust leak somewhere along the line. When I first put custom pipes on my Roadster it was obnoxious until I went back with some copper gasket seal and re-torqued the bolts- night and day.
Journeyman is correct. The new Rockets have an exhaust burble that some may think is decel pop and this is normal. Check for leaks as is suggested. If it is new and stock you are most likely WNLs.
