Dead man throttle control
Love it! Easy to engage, took 3 minutes to install, lets you "tweak" it as you go. Looks great!
It is a throttle lock though, so good for flats and steady wind. I use mine when I need to stretch my wrist a little.
IT DOES WORK with HEATED GRIPS, but NOTE that when you disengage it and don't leave enough room, after turning on the grips, the expantion may make it bind a little.
Solution: when you don't use the throttle lock, "unscrew" it a half turn more than you would do with regular grips.
Sorry about the pic being out of focus.
I ordered it from http://adventurersworkshop.com/Merchant ... KO_TROCIII and am satisfied with them.
Just a quick word of caution on this. If your throttle control device keeps the throttle from completely closing ( all the way to zero ) when you start the bike and it goes through its calibrations it going to whack your tps. I think the same with the idle screw fix for the idle problem.
ROCKT3, this thing either keeps your throttle in position or not. One would notice if it was revving at 5k! :)
I doubt this would be a problem.
