Darkside
Greeny,Thats what I have on my R3T, it will feel a little bit different when you first ride it but you will quickly become used to it. Keep the pressure around 34-36, do not worry about the slight squishy feeling, just ride it like you would a motorcycle tire.
The squishy feeling means that the tire is doing what it is supposed to do, flex and keep a large contact surface on the pavement.
Contrary to what some Darkside non -believers say, it will NOT go onto the side walls.
You will have twice as much rubber tread on the ground as you would with a motorcycle tire when you are doing very tight turns, so do not worry or think that your tire will slide out from under you, it won't.
