warp9.9
Pocałuj mnie w dupę
I changed my coolant last night with engine ice and have a few questions. I did the change as per work shop manual. First the book says it holds 3.2 litres, I could only empty 2 out of it from the bottom radiator hose and that’s taking out the water pump drain plug which no fluid escaped from there anyway or barley a trickle. I filled it with demineralised water to flush it. The dealer said that was necessary due to the fact engine ice doesn’t mix with other coolants. Again could only put in 2 litres and take out about 2 litres. I unscrewed the bleed screw and poured in the water and the coolant in till it ran out the bleeder which means it’s full but still could only fit 2 litres in it. The worry is it’s not even showing in the overflow tank. Ran it toped it up ran it took off the cap checked it again but still not showing in the tank. It doesn’t have a temp gauge so I don’t know if it’s running hot but the light isn’t coming on and it’s really hot here in Brisbane right now. Thanks for any advice
Hey bud there is also a plug on top of the thermostat housing to let air out if you crack it loose and take it out (watching not to drop the sealing washer) you might get a little more out. Plus raise the back of the bike up with a jack to make sure you get all of it out of the liner cavity. I will get a picture attached to this reply after me old ass gets out of the whirl pool!!!!!!!!!
Ok me bones have been jump started heres the picture of the plug which you need to remove to let air escape as your filling it up. Which will help as you drain her. Like I stated the engine is lower in th eback so coolant will remain unless you jack the rear up first.
Hope this helps
