Boog
Traveling Story Teller
- Joined
- Oct 17, 2013
- Messages
- 8,487
- Location
- Dumfries, Virginia
- Ride
- 2014 R3T, RAMAIR, Full Viking Dual exhaust
I just returned from 2 weeks on the road with work, unfortunately, I had to leave the bike at home. When I drove up late that night, I notice the bike cover was pulled up in front. Usually this is the HOA security checking to see if my inspection sticker is current (but that is another story).
I rode to work the next day and forgot about the cover issue. I did a quick inspection and everything looked ok, I kicked the tires on the big beast and off I rode. Something didn't feel right in the front end. The tires are new with about 400 miles on them so I knew that wasn't the issue. Then it dawned on me to actually check the tire pressure; there wasn't any! I first thought my tire gauge must be broken but it worked on the rear tire and should a nice 45 PSI. But the front tire had nothing to show on the gauge yet it looked completely aired up. It even felt solid to my squeeze (guess I better hit the gym and work on my squeeze now). I grabbed my tire pump and inflated the Exedra Max and it is holding just fine after several days of use now.
Two big points to hit on now:
I know how lucky I am and how important preflights are. And I know I need to talk to security about patrolling my section a little better...
- Always conduct a proper check before riding. I learned a kick of the tires does not count with good quality sidewall tires.
- Bridgestone Exedra Max tires, even when empty still have a tremendous amount of strength when riding. They are not like tires of old that look flat when half full; these suckers held my 865 lb. bike and me at freeway speed and all I felt was a slight wobble on the tar snakes.
