xlr8tion
Turbocharged
HEY SO YOU ARE GOING TO PUT ON SOME TORS.....But how do you...
Remove the broken tail of the bolt from the Clamp?
Triumph makes the clamps out of SS and the bolts are galvanized and soft, I think, so they will sacrifice if you try to over tighten them and crush the pipe or cat outlet and conversely they snap when being loosened so the techs can get them off in one revolution and charge you for a whole new clamp.
I got some absolutely mint tors with perfect gaskets and the clamps had bolts snapped on 3 of the 4 clamps(manifold and two of the three tors)
I have soaked them in Vinegar to dissolve the rust then I will soak them in Kroil and try to make the three turns clockwise with a vise grip(then the end of the bolts threads are ruined so its only coming out that way..No reversing it....
Does anyone else have any idea how to remove these soft bolt frags out of the clamps so I do not have to fork over 40 bucks for a set of 4?
Attached is a pic.....
Thanks...Greg
Thanks...Greg
