rolandrat
.060 Over
37k miles,remove and grease shaft spline every tyre change along with diff oil change.09 bike.it does it at slow speed over speed humps.thanks for the replyRocking the bike back and fourth to make sure the tensioner adjust will not do anything to the rear. Is the clunking there when you ride it or just when you rock it? Also I see you have a what year?
You should drain the bevel box and check what comes out. Then if you have never pulled the bevel box off the swing frame to inspect and grease the drive shaft splines you should. Also how many miles are on her? Lastly we will see how that goes and eliminate the bevel box and splines first before we drop the hammer.
