Well, after my output shaft bearing failure, i was able to procure an update kit from Triumph thru my old dealer in Florida free of charge. (Thanks Dink!) Anyways, iv'e got the motor back together but am having an issue getting the crank and cams to time correctly. Seems like no matter what i try, the crank gear is always running about half a tooth retarded. With the cam fixture tool in place holding the cams and the crank gear on TDC, i cna't even get the cam chain to fit the gear. i end up having to rotate the crank back a bit to get the chain on the crank gear and end up about a tooth off. Any ideas out there? Thanks, Bigern2300
