Bugger!!! Water pump leaking
My R3R had very slight drip from the water pump from new, the water pump was replaced under warranty. If I recall correctly I think there is a oring on the shaft where the pump goes into the motor, your problem may the oring. I had a look in the manual and there is an oring.
Hope that helps you.
