HellFire
Legend
- Joined
- Aug 16, 2008
- Messages
- 4,518
Carbon build-up? Dude, you aren't thrashin' her hard enough! Little old ladies get carbon build-up!
Just kidding.
Thats our bad gas again, but enough to stick the valves open?, wow that sucks.
Wherever you are buying your fuel is even worse than normal, if you HAVE to get your gas from questionable stations you should start using Techron fuel treatment. It's about the only product out there that reduces carbon already present on valves. You don't have to use it everytime you fill up, just every 3000 miles or so. I've been using the stuff since the 80's in all my cars and bikes, it keeps the top end of my engines totally free of build-up and the injectors spraying like new.
BMW's back in the day were notorious for carbon, it looked like chocolate cake around the valves it was so bad. The shop I worked at used ground walnut shells to blast it off so the heads didn't have to be removed. Our customers that used Techron at every oil service never had to have it done. I've used it ever since.
