Back turn (direction) indicator lights issue
maurice
Turbocharged
Tucson,AZ
2020 R3 GT
when u try to diagnose something that is working u will get its working answer.
if u can test when not working then your chances r good to find the problem.
do u really want them to start guessing? that can lead to more problems!
very true check with main triumph some one may have found the problem (not likely to tell us)
when my buddy @maurice has the problem then we can fix these :laugh: :laugh: :roll::roll:
We hope.🤞. We were not too good at figuring out the intermittent power cut off if you remember. Dealer suggested gas overflo into canister by overfilling. He was wrong that I was overfilling, but led me to solution.
Gibbi
Rocket 3GT
Well you’re not alone my R3 GT just threw that warning light on the dash telling me front left indicator out.
Switched off the ignition and re started all back to normal, then happened again a short while later with one of the rear indicators?
I have 5000 miles on the bike and this is the first time I’ve experienced this problem.
Will see what happens next time I ride but I will be giving the dealer a call.
jlagrave
NJ
2020 Rocket 3 R Phantom Black
I, too have experienced the indicator warning lights. It's happened to at least 3 of them by now. Definitely a can bus/ecu issue. Connections are fine, and it seems random when it happens. "Fixes" itself if you just put the blinker in question on for a bit. It'll eventually go back to normal operation. Annoying. Haven't been able to visually document yet. I wonder if its a load/current draw of the LEDs and some parameters in the eco not jiving. Who knows.
Zutt
.060 Over
Parts Unknown
2020 Rocket 3 R
Does it just give a warning light, or does the opposite blinker actually turn on. If it's the latter, one would think this is potentially dangerous for the biker and should be getting Triumph's attention to come up with a solution or a recall.
Probably the group who are experiencing this should report this formally, so Triumph is forced to pay attention.
jlagrave
NJ
It never mixes up indicators, but they do fail to, indicate and the warning light comes on. Like i said, it eventually fixes itself, not that I'm condoning it. My assumption is I will have to document it to have it go anywhere with triumph. So will try to do that.
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
A picture of that warning light would be nice
When the turn signal self cancels does the warning dissapear
jlagrave
NJ
I have my turn signals set to manual, so I have the cancel them. The warning light, when it happens, comes on with the message that the indicator has a problem (i forget the exact language) and you can click ok on the thumb controller to dismiss, but the warning light stays lit. when you put the blinker on again, the arrow flashes faster (like when a bulb is out) until it eventually fixes it self.
Gibbi
Rocket 3GT
As said if the affected indicator is left on it will normally reset itself, however on my last ride lost all indicators, no warning light, no direction arrows on the dash and no indicators at all.
Stopped the bike switched ignition off and restarted, all working again?
Have booked the bike into triumph, they told me they had a bike last week same issue, reckon they pushed on all the connectors and cleared it. I’m not convinced will wait and see what happens when I get my bike in to them.
In this condition the bike would not pass an m.o.t. Test, so to my mind that makes the bike un road worthy, not good for 11 months old 😕
AdBlock Detected
I've Disabled AdBlock
