Auto Tune question
Thanks for the suggestions, I will have another look today.
The PCV&AT have been in the bike for a few years could O2 sensor the problem, how difficult is it to test and can it be cleaned.
If you suspect the O2 sensor - JUST REPLACE IT. They're not that expensive. And a new one won't hurt.
But from that message I suspect it more an electronics connectivity issue - I'd call Dynojet or their Aussie rep.
I emailed the problem to Dyno Jet, I checked the AT is getting power. Also screwed out the O2 sensor to do the tests that came with the instructions, could not get the light on the AT to come or flash. I am sure what that means but no doubt the guys at Dyno Jet will know.
To remove the AT, I just discount the power source, disconnect from the PCV, screw out the O2 sensor from the exhaust and screw in the plug from PCV kit. Then the the fuel map in the PCV is controlling the Air/ fuel delivery.
The final solution, when i could not find the problem decided to remove the AT. While doing so I found there was a power supply problem to the AT, anyway I continued to remove the AT.
