Any older cold blooded Rockets other than mine?
mexican
Tulsa OK
2012 Carpenter Silver BACK240
Had my battery on a tender, did not started it for 2 months, now it refuses to start, it turns maybe half a turn and it stops, sometimes it just clicks.
I went ahead and bought a new AGM battery, connected it and it does the same. I always have this issue in the cold weather but this time is abusing the privilege.
Am i the only one? o_O
Guys, need the gurus on this one, went to try to start it, it just clicks, new battery shows full, hooked up the battery tender in case it was not fully charged from the factory, been charging for a few hours and battery tender shows green.
It acts like battery is low, when i hit the button it just clicks and lights dim down to almost nothing stay like that after i release the button, it also loses voltage to the sweepers, one may sweep and the other one does not, also light on the speedo gets very dim and sometimes after the click all electric dies, Everything indicates low battery but old battery had charge and new battery does too. Any ideas? Never had an issue that i couldnt figure out with my Rockets, this one has me puzzled, had not spent lots of time on it but looking for ideas. Thanks in advance!
If it was a car, I'd say sand down the battery connectors. This is a stumper. Fuses are cheap. Try replacing that one (can't remember what "That" one is right now, though.)
Hope you get it figured soon!
You mean the 30 amp main fuse?, will check all fuses tomorrow. It was working great, i just gave it a 3 month break and it did not like it
