I wanted to thank
@Rocket3Pilot for his write up and further discussions we have had. Also thank
@D04011 for generously donating a set of stockers for my de-cat project. I want to also give my take on how to best remove the cat from the mufflers, believe me if you go about it the wrong way, and I did the first one, but I learned from my mistakes, you'll enjoy a tooth extraction more. The first took me 4-5 hrs of tough work, while the second took only 2-3 hrs of relatively easy disassembly.
Once you cut off the ends, easily done with a hacksaw with a good blade, you are faced with a dense pattern of very small holes in a metal film that is not brittle and will not cut, but will bend and flatten out, making it very difficult to remove. so.
for those of us that noise is a problem,
-starting with a 1/4 in drill bit, make a hole in the center of the cat material, then enlarge it with a 1/2 in hole all the way through, around 4.5 in or so. You will have removed little material at this point.
-now take a screw driver about 3/8 in wide and force it between the next two layers near your 1/2 in hole, tap it in with a hammer and -once snug in the cat material, twist it, to fill in the 1/2 in hole you created.
-go all the way around the 1/2 in hole, filling it in with the adjacient cat materials. you'll be creating a larger hole area about 1 1/4 inches wide, but not so deep yet, maybe 1/2 to 3/4 or an inch.
-now take a 1/2 in wood bit, in a power drill and work at the area you've created over the 1/2 in hole. You can try other sizes of wood bits too, larger, you want to break off the folded in area, it takes some work.
-continue all the way down to the bottom of the original 1/2 in hole, to creat a new hole about 1 1/4 in wide. this gives you an area in which to work.
-now go around the 1 1/4 in hole and seperate 2 layers of the cat material, drive the screw driver in and twist, loosening the walls, do not fold all the way into the center, just break it away. Move along and break away 1 in of the cat material.
-now take a pair on needle nose, heavy duty ones, grab the loosed material and twist and break away the cat material.
-continue around the 1 1/4 hole, all the way.
-now you have a larger hole on top, maybe down an inch or so into the 1 1/4 hole, but now it's larger near the top. Continue on down the hole, until the entire length of the hole is cleared to the new diameter. Near the bottom of the hole, a long pair of needle nose is a must, 10-12 inches. You are grabbing the loosened cat material and twisting it loose.
-start at the top again and repeat what you just did. Making the hole uniformly larger each trip
-continue until the cat material is removed.
- take your time and in 2-3 hrs it'll be done.
Hoopla
