Well here you go. The wires were loose in the wheel well. Not really that bad. Brake light red wire almost wore through. Right turn signal both wires a mess. Started working through the protector cover on the license plate wires.
Easy fix once I get the wire and heat shrink tomorrow.
I wonder why it's not on the Roadster? I have a signalminder on my 05 which I love. Probably going to put one on the 011. It's so easy to not cancel the signal and possibly cause an accident.
Because the signal control is part of the instrument, which is completely different on the Touring - the speedo on Touring is bigger, mounted in the tank - more 'cruiser' style; the Roadster gets a tach instead
Triumph dont make instruments
They purchase that one for the touring as a style/functional element for the Touring; the same features/capabilities probably dont exist in the size/style they want for the Roadster
You said yourself- you can add aftermarket one easy enough so not a huge omission
Do you use the tach much?
I have one on my America and I really do not use it that often.
I have thought about putting one on the Rocket. The engine sounds so much different and I find myself checking to make sure I am in 5th gear at cruising speed.
