BillyIndiana
Road rash heals-Freckles grow back-Ride
So as I stated in my other thread my signals stopped working Saturday.
Tonight I
Checked the bulbs OK
Checked the fuse OK (Brake light and horn are on same fuse and work)
Got out the manual and stared working through the circuit. It seems whatever controls the indicators is in the instrument assembly.
Took the Instrument Assembly off. Unplugged it and plugged it back in making sure the plug is seated. After doing this the left indicators seem to be working, but the right does not and when I activate the switch I see the lights on the instrument console dim for a second.
This is leading me to believe that the fault has to be in the instrument cluster. There is no relay or blinker in the circuit that i can see and knowing that the blinkers are auto cancelling it makes sense that the issue is in the console.
There is a Diode Pack in the circuit, but I believe this sends the signal to cancel the turn signals from the instrument cluster.
There is no breakdown of the circuits in the instrument console that I can find.
One thing that perplexes me is I do not see the ignition switch in the complete electrical diagram?
Anyway can someone verify my logic on this.
Thanks
Tonight I
Thanks
