Bauerman
Standard Bore
- Joined
- Mar 23, 2024
- Messages
- 7
- Ride
- Rocket 3R
I have a 2022 3R and after 5400 miles the 7.5 key fuse is blowing out while riding. The problem with this is the bike shuts completely down with no warning and won't restart. I replaced the 7.5 fuse and the bike would start a couple times and then blow out again. The bike cannot be ridden with this condition very unsafe. I was wondering if anyone has had this problem. Until I can start this bike and pull the 7.5 fuse without bike shutting down I'm done with it, this will get you killed. No Motorcycle should shut off like this over a key fuse. For safety sake I would suggest you start your bike and do the same. If it shuts down you have a problem because your one small fuse away from becoming a greasy spot on a busy road.
