600 mile service
OH, supposedly they will do a complete check of the bike looking for loose nuts and bolts, change the oil and help to lighten the load on your machine by removing some weight from your wallet !
Dog
But check and see if your doing it yourself will not violate your warranty!
Oil change and as Rude Dog stated, just a bunch of checks. You can view what is in all of the service checks on Triumph's web site.
Mine never saw a dealer for that "service". Later they still replaced a couple of items under warranty. So go to Autozone and buy some mobil one 4t oil (5.5 quarts) and I always get the k&n filter (KN-191). You will probably have to call and order the filter if you want the k&n. The crush washers can be reused a couple of times and they will be on the bolt when you remove it, not stuck to the crankcase! The oil is $10 a quart and the filter is $14.
