Ah, bad luck there - good on you for at least getting into it.
If you prefer not to use butt splices to butcher your OEM harness, you can go one of these routes:
a) Replace the male connector on the new key-switch to match old style - 250 Series Motorsport Connectors - Corsa Technic
b) Replace the female connector on the main harness with the new style directly - 8-Way Kit (get largest terminals and seals)
As mentioned earlier you should definitely look to a headlight-key-switch-bypass mod or it will surely happen again; this is the simplest way to achieve that with a single relay - New member in Japan: 30A fuse blowing (horn, turn signals)
Ignition Switch & Lock Set - introduced from and after VIN 343681 i.e. mid 2008 update
2 Switch, Ignition, Text T2501072
BACK ORDER NO STOCK
inc. VAT (£128.52)
US$129.97 excl. VAT (£107.10)
When I first came on forum i too had a key switch issue and found guys had fixed wire, installed a 40.00 keyless directions in signature of idk, the guard dawg but many were recommending the decosse system as being the shiz nit, I like shiz nit, and I’m glad I listened itsplug ang play professionally made with customer service that is incredible. Get the best once if you can and be done with it as the ignition switch can be an issue for some,
Here are two versions New Old Stock make an offer. I have made 1/2 to 2/3 rds offers successfully from this seller before.
https://www.ebay.com/itm/TRIUMPH-ROCKET-III-IGNITION-SWITCH-AND-KEYS/123440321042?hash=item1cbd9dd212:g:qQ8AAOSwIUpby4~y
  • Fits Triumph Rocket III
  • Classic or Roadster
  • Vin # 343681>
TRIUMPH ROCKET III IGNITION SWITCH AND LOCKSET KIT | eBay
  • Fits 2008 Triumph Rocket III
  • VIn # 343681>
  • Vin # 343681>
  • VIn # 343681>
Someone beat me to it.
