2025 R3 Storm
I found a 2022 R3 silver/red with a werks slipon I tried to purchase for a week and gave up today to buy a new leftover 2025 R3 Storm. Have a look.
I have the 2025 R3 Storm GT - same color! Added Werkes slip on & will be replacing the turn signals with pin lights. Wonderful machine; I enjoy mine a lot. Happy & safe riding!
When you took delivery of your new bike the suspension was set to no preload. That will break your spine in short order because there isn't any travel for medium to large bumps. There should be a preload adjuster on the left side under the seat. The table in the owner's manual is garbage; you need to add preload to add shock travel. It should be fully clockwise so that it can't be turned anymore in that direction. To add preload, you turn it anticlockwise and it will 'click' as the preload is added. You can start with adding maybe 6 or 7 clicks and see how that feels. To get it right have someone measure your static sag while you sit on the bike and then adjust the preload until you have about 30 to 35mm of sag. The damping adjusters are on the right side under the side panel. Back that off (anticlockwise) to no damping and start from there after a few rides to dial in the ride quality.
Motorcycles
How much do you weigh (6-7 clicks)? And do you carry a passenger or have panniers added? Thanks!
I have mine set at around 10 clicks because I weigh 325 pounds. No luggage and no passengers (widower). That recommendation comes from owning 6 Triumphs and having to dial the suspensions in on all of them. The number of clicks is a starting point, not an end point. The rebound damping can make the ride harsh too because the spring is restricted from returning to full extension by the damping action fast enough that the next hit can bottom the shock. By removing all damping the spring isn't restricted. What you dial in damping for is to stop the 'pogo' effect if you get that. At my weight I don't.
Appreciate it; thanks!
I usually press it twice out of habit. It sometimes doesn’t catch the first one. Top button resumes set speed or increases by 2MPH every press. Bottom press will subtract 2MPH with each press.
First press (down) turns Cruise Control on. Second press (down) sets the speed and activates it.
Mine increments/decrements by 1 MPH.
.You can also set the turn signal to auto deluxe or something like that. Where a soft press will give you three blinks and a harder one will give you the normal distance/time auto shut off.
Quick press or longer hold. It's not pressure-dependent.
First press (up or down) turns Cruise Control on. Second press (down) sets the speed and activates it.
Thanks! I would sometimes press the turn signal slowly/softly and it would go to the long blinks. Now I know to just press it quickly.
good stuff, my weight probably comes in around 150lbs geared up. Throat cancer treatments destroy saliva glands and makes eating a chore.
I rode to Cycle Gear today and if my new bike had hands it'd still be signing autographs! Everyone had something to say, Is that a Rocket 3, can I take a picture? How many cylinders is it? is it heavy? How fast does it go? Wow that's a tough looking bike(my favorite). An old Harley/Triumph rider hung out 10 minutes or so, another BMW 1800cc boxer owner came over, guys with girlfriends standing around with light rain coming down interested in this creation from Triumph.
