Mongler07
Turbocharged
as you know I have that odd cranking issue but that's not the question here but may be part of the problem that might get solved by fixing this issue.
Today when I started her (cold) the starter would not stop cranking. I turned her off key out and cranking kept going. I pulled the seat up and yanked the 30 amp main fuse and it STILL kept cranking. Pushing the starter button repeatedly and tapping the starter and the ignition controls did nothing. Eventually the battery lost enough charge that it stopped cranking.... I believed this is because the contacts were welded together?
The problem could not be replicated after this event but I only tried a dozen times or so.
Relay?
I just rebuilt this starter and it's a new battery.
I was not next to my tools fast enough to take the battery off. The negative was MUCH hotter than the positive after this event.....
Relay?
