My Rocket has developed a stutter. Starts and rev's smooth under no load. Under load above 4500 RPM she bucks and thrusts. New tires just installed front and rear. Any suggestions???
Yeah I'd be starting with the low tension leads to the coils the front (number 1) coil is hidden up in under all the wiring in the back of the head stock wiggle you have them disconnected tighten the female connection up with a pair of long nose pliers and put a dab of Dielectric Grease on the connections
My Rocket has her voice back. Found the coil mounting bracket loose and pinched the leads to all three coils. Test ride results, pure performance. Thanks again
