Mark Dunn
.060 Over
Hi all,
I have an 09 standard (bought new in May, now 2300 miles) and decided I want a bit more 'oomph' in 1st and 2nd. However, I didn't want to go balls-to-the-wall like the GiPro does (at least, not at first). So, I modified the factory standard 20222 a smidge. Anyhow, I hooked up Tune ECU for the first time today (works well) and noticed that the installed tune was actually 20225, - which is the tune for TORs with cat in place.
I decided to load the regular 20222 tune instead of my bastardized effort to see what it's like. Well, it's smoother, about the same response-wise and has no decel burbling (the 20225 never actually popped). Gear changes are less jerky too. Why a new bike had the wrong tune in it I don't know. Any ideas?
Secondly, while hooked to Tune ECU I decided to check my primary TPS adjustment. I couldn't get the voltage reading any lower than 0.61V and no higher that 0.62V, no matter where I adjusted it to. Obviously, those voltages are within spec' (just) but I was surprised at so little change. Is that normal?
Regards,
Mark
Regards,
Mark
