Which Tune?
John Ward
.060 Over
York UK
Rocket 3 Classic 2008
Hi Guys n Gals
Just been on the tune ecu website looking for the correct tune as mine still has factory tune installed. My bike is a 2008 classic with production pipes but no cat.... on the website there are tunes for classic, roadster and touring, but then above them a section of tunes for rocket 3? So my question is do I install the tune from the classic section for production pipes with no cat which is 20220, or the tune from the rocket 3 section which is 20227?... confused!
Also after I install the tune, do I need to turn the ignition off and on for 10 seconds which is indicated on a small vid clip I watched on here somewhere, and then reset the TPS... then start the bike and let it run until it goes green in tune ecu again..
Cheers in advance!
Hmmm ok so doesn't anyone know which would be the correct tune for my bike? Ill download and install 20220 the one from the classic section, I just didn't want to have to do things twice that's all and have to go back and install the later tune from the rocket 3 section.
Send a email to Hans0 pretty sure he will have a tune to suit your setup
Probably a lower speed limiter on the classic tunes verses the standards. But both sjoild work fine.
Oh yea I had an issue with my running lean after installing pipe tune Ecu is a good one I had to do another download you don’t run the bike during process key on to connnect then download map I used the same tune you mentioned I had to go to the one listed for or close to what set up you may have I believe mine was 20227 if you can save your old map on pc I did not had to do it twice was real scared I was going to screw up HANSo did reach out ( thanks I was stranded in fla but him and joesome are the best great place to get info on r3 got mine back from the dead It’s alive drove to Disney booking down the hi way 90+
Thanks so much Hanso steered me in the Wright direction if you don’t map it write bike would run like s:;;t man what a difference
