Mongler07
Turbocharged
I have the clutch cover off now that i fixed the bosses on the block but noticed the cover is cracked in 2 places from PO dropping it.
the new cover (used) that i got has the same issue. the seal is torn / worn though and the spring is coming though. i found the thread here about this part and ordered a 5mm hight seal instead (hoping it will work) as the 4.5mm one will arrive in a few weeks vs tomorrow!
I Found only 2 posts that mention the " Warps spring mod" and i searched Geralds posts but didn't find anything more.
Questions
1: what spring was used? (i'm sure i can figure it out.. but might as well ask to be sure)
2: can the shaft be removed completely to change out this seal once the cover is back on? i would like to put it all back together but i'm waiting on the seal.
3: what's the real reason to do the external spring mod? is the one internal going to snap? i saw the detent spring thread... yikes!
Questions
