I believe that the bracket came with it. It's a little flimsy, but it's lasted 3 years now, with no end in sight. Just need to tighten it up every now and then.
Hey there, ksquared. Great choice. I've been wanting the Koso for a while. Three hours? What were the issues? Is it too difficult for the average bear (mechanic). Could you post some pix to show the problem
spot and what your mechanic did to solve the problem. It would be really helpful to others considering the
Koso tach. Maybe even a list of bits and pieces needed to help complete the install?
The little bracket Koso gauges come with - WILL fit 1" bars perfectly IF you take the rubber sleeve out. 7/8" with the sleeve in. It is however rather tacky looking. It's Stainless steel. The "Y" shaped arm it mounts to has rubber damping too - so no issues.
I used a different method to locate it below and between the R3 standard gauges.
Awsome...
Just picked up on this thread and bought one, exactly what I've been looking for.
I guess the time consuming part would be accessing the top radiator hose to fit the Temp Sensor Housing. Thanks ksquared.
