Geoff Smale
- Joined
- Apr 13, 2017
- Messages
- 17
- Location
- Whakatane New Zealand
- Ride
- 2005 Rocket 3 ,1971 Kawasaki Mach3
I have read many on many forums over the years people asking questions re the need for re-jetting of carbs on their bikes after fitting less restrictive exhausts and air filter and I totally under stand why as the less restrictive air filter will have an effect on the metering of a carburetor ( less vacuum) effectively sucking less fuel through the carb's jets. But my question is with a fuel injected engine, the fuel metering is done via a calculation based on mainly the engine speed, air flow, temp and load etc so freeing up the inlet air flow would make little if any difference to to actual mixture ratio ( you dont suck fuel through a fuel injector). Bearing in mind that the factory fuel curves are based more on meeting emissions and fuel economy than outright performance i can see the potential gains that can be made in smoothness and performance that a revised tune can bring, but is there really any real need to amend these fuel / ignition curves just because a less restrictive inlet and exhaust system have been fitted the a Fuel Injected bike.
