... Its hard to make the choice as i dont know what the shop did with the ecu i supoose i am just going to have to pick one and i will go with 215 fro now.
I would say not to worry too much about what the shop
did install and just go with the map that seems to best reflect your configuration and with OEM pipes and cat-box then that would be 215.
If OEM exhaust, the part number should be directly on the exhaust itself
This is OEM right side upper exhaust part number 2208414: (bottom one is 2208415)
You can see where the part number/emissions label location is on the inside of the exhaust
I don't think so, although we may want to zero it. (more on this later)
.. now it is starting everytime and idling about 2 to 3 seconds. when reving just a little bit it will keep going but without this it will go back to idle for about 3 seconds.
So you have definitely improved the situation with fuel rail and injectors being cleaned, which suggests your issues are/were primarily fuel based concerns.
I sound like a broken record, but please try to measure the fuel pressure - even a cheap gauge is going to be adequate.
Call your man at the injector shop & see if you can borrow one, on a deposit if necessary - you literally need the thing for 5 mins.
Also, try to get MAP sensor readings, even if it is slightly higher engine speed than normal idle.
This is what I would do at this point (assumes you can get the TuneECU program to reconnect)
1. Ideally check the Fuel Pressure - this may not be an issue, but you really need to know to close that chapter. Given all the things you have done in the fueling department I think its important to have this validation before you start to do any re-mapping.
2. Install the appropriate map (215?)
Download and save the map from the TuneECU website
Extract the map from the zipfile into your folder
Remove Fuse 9 (or disconnect headlights) and turn on Ignition and Kill Switch to Run
When TuneECU connects, 'read map' from the ECU menu
Once the map is uploaded to the program, select File -> save map and save to your TuneECU folder
Turn off Ignition
Now File -> Open map and navigate to the folder to where you downloaded the extracted file (20125 map) from the website
Turn on Ignition, and once you get the green 'download' icon, click that and it will start the download of that file to the ECU.
Allow the download to complete then turn the ignition off, then on again
3. Check the TPS zero:
a) Turn on ignition, go to tests page and click the 'adjust iscv' - this will set the stepper for the throttles to fully closed position
b) check the voltage of the TPS (you can read this directly on TuneECU on the bottom dial of the three smaller ones) - it should be 0.6V +/- 0.02 i.e. 0.58 to 0.62V (even if at extreme don't worry about)
c) if not within that range, loosen the TPS screws and rotate the TPS to get within the range.
d) double click the 'adjust ISCV again - stepper should drive open - voltage should now be 0.75 +/- 0.05 i.e. between 0.70 to 0,80V
e) double click again to to end the ISCV adjust process
4. Replace Fuse 9, then Start the bike and get it up to normal operating temperature (90C), assisting with the throttle if necessary
Once it is up to operating temp, the closed loop system will kick in and will help to bring it into control. Ideally it will idle unassisted at this point.
At this point, shut it down and proceed to step 5.
5. Re-adapt the system -
Select reset adaption from the main menu ECU tab
start it and let it idle with the throttle closed and then leave it alone to complete the adaption process. It may hunt a little during this process but eventually should stabilize out as it learns the trims and 'adapts' the fueling from what the O2 sensor is seeing.
You can find more specifics on the processes on the TuneECU site -
