hey everyone started to install the triple k&n's on my 08 rocket iii when i removed all the intake air tubing there is a air flow??? sensor my question is what do i do with this. i ordered the air temp sensor filter from k&n does this go over the sensor. i also ordered the crank case vent filter where would that be located on the bike. i am used to working on my wing and new to the rocket thanks for any help you can give me.
..look at MDs sticky in the how to section..a couple of pics there..that's where I put mine..as for the crankcase breather, take off the right side cover and shine a light in there..I used the hose that was on there to put the breather on..ain't no way in hell I could put that breather in there without it.. :lol:
I tie-wrapped the sensor to the frame just above the intakes.
To mount the crankcase breather remove the plasitc cover (2 allens) on the right side then put a crow-bar against the air box bottom and the tab top that holds the plastic cover and lift about 3/16" to clear the filter over the breather outlet tube and under the airbox. Otherwise you'll be real frustrated. Once you slip that over cinch it down.
i have just started the work so going to attemp the sw relocation tomorrow weather permitting will let you know. and thanks for all the answers to my questions everyone. RIDE SAFE
