Stebel compressor mount
jthree
Turbocharged
Ontario, Canada
2007 Rocket III Classic
I know this has been discussed before but I can't seem to find an answer that works for me.
I have removed the compressor from the horn and will mount the horn in the stock position but I'm having a real hard time finding somewhere to mount the compressor. I have tried under the left side cover but have next to no room there. I have a key-less ignition system, the buttons for which are mounted on the side cover and the controller is in there too.. The only place that looks like it may work is strapped to the frame tube towards the rear of the left side cover. This would have the compressor mounted on, more or less, a 45° angle, is this OK? The instructions say to mount it upright (not sure why).
Is there anywhere else I can mount this thing? The "Road-Runner" horn has to go!
Cheers
Jthree
options, options. all depending on what else you've done.
IF you have done the triple K&N filter mod, you can use the old airbox.
or, you can use the frame tube just under the coolant tank.
or, if you have the engine dresser bars, you can use it as well just below the coolant tank. no really hidden but it would work.
