Mark Dunn
.060 Over
Hi all,
My Rocket is a 2009 standard with Eastern Beaver headlight mod', original pipes and cat box. I recently replaced the battery negative cable using 4 awg cable it and made a noticeable difference to the ease of starting. I'm looking at replacing the positive battery cable too, but the bolt that holds the positive cable to the starter motor is rather inaccessible.
To completely remove the starter motor would involve removing the cat box (and probably the left side exhaust, too), - which is a pain. Does anyone know, if after removing the starter motor's two fixing bolts, it can be pulled a little back and rotated enough to gain access to the positive connection bolt?
Thanks!
Mark
Thanks!
Mark
