Willtill
Nitrous
Hanover, Maryland
Ran some Star Tron today in my Rocket... had to make a quick 104 mile dash to work and back to swap out some ethernet cables.... :roll:
Anyway, on the ride back... I was running down the Interstate at 90-110 mph and the motor was just abnormally smooth even when almost hitting a constant 4k rpm.... I've never felt the Rocket run this smooth at those rpm's at interstate speeds....
This is Star Tron:
http://mystarbrite.com/startron//content/view/93/123/lang,en/
Usually I'll dose my fuel tank(s) with SeaFoam periodically to clean everything out in the fuel circuit; as well as prolong the shelve life of the fuel... but Star Tron seemingly is enhancing the fuel burn. I was getting a lot more responsiveness today... not so much on the first 50 mile leg... but on the retun 50 miles back home.... I really was enjoying the throttle and the ride.
Give Star Tron a try. ;) It may be replacing SeaFoam in all of my applications. Certainly seems to do better; at least operationally when I'm running an engine....
I saw a Mythbusters recently.. they were testing myths of stuff shoved into engines ( bleach etc)
One myth was Napthalene.. supposidly an octane booster ( apparently in Star Tron.. looking at the specs?) their engine was a big V8, & guess what? yes it ran way smoother with this additive.!!
Just throw a few mothballs in the tank your all set...not only does your bike run better but you smell like grandpas old wool sweater.
Did you use the small engine version or the Marine (standard)
The rocket is not very small and a few outboards match the size of Rockets
This is Star Tron:
