It's a auto meter Dpss level 2 shift light. Running off the negative side of the coil it won't read rpms. I am going to try it on a car tomorrow to verify it works. All you have to do to get it to work is set the ignition pulse for the correct setting, or it will read the wrong rpm. The fact it's not reading any rpm has me puzzled.
I think I might just buy a different light that has a pickup that goes around the positive wire, or even a injector wire. Those will work on anything
The ignition coils appear to be directly powered by the ecu on the rocket, or atleast that's what the wiring diagram shows. It's possible that the spark pulse signal that is being sent out is not compatible with the shift light. Who knows
