DKB&R3
Standard Bore
All: I have been rebuilding the engine (replaced the output shaft bearings) and am nearly done with assembly but the clutch is not operating correctly; can someone let me know what needs to be done.
1: the clutch was NOT touched in the motor, only the cable and lever were removed.
2: the engine is drained of oil, will fill after the pan is dropped and cleaned out of ground bearing.
3: the clutch cable has very little to no resistance currently.
4: I can manually rotate the clutch leaver by hand with little resistance too.
Will adding oil solve this or is there a step I'm missing?
Thank you for any insight....DKB
