Running rough in lower revs
Seems like switching the coil/wire to a different cylinder might be the easiest way to see if those parts are the issue.
my old ears is not real good but was wondering that if you pulled one of the two plugs on each the cylinders one at a time if that would identify the cylinder that is making the noise.
i know that is a long shot so if you do not want to try it i do not blame you.
My bike after getting home from work
Thank you so much for taking the time to record and share this! I really appreciate it.
After listening carefully, I can hear that the random “boom” pattern is exactly the same as on my bike. Your exhaust is different from mine, but the pattern itself is identical.
Thanks to your recording, I’m now pretty confident that this is simply part of the Rocket 3’s normal engine character.
My theory, which I’ve also seen discussed in similar threads on Rocket 3 forums, is that emissions-related fueling at low RPM and light throttle may contribute to these occasional weaker combustion events. That could explain why the random “boom” sounds are more noticeable at steady throttle or when gently rolling off. Of course, this is just a possible explanation rather than a confirmed diagnosis.
It’s a relief to finally hear the same thing on another Rocket!
I’d also like to thank everyone who told me from the beginning that this was normal Rocket behaviour. I guess a short answer would have been enough after all! But on the bright side, I’ve learned a lot about the Rocket 3 and how its systems work throughout this whole investigation, so I certainly don’t consider the time wasted.
Thanks again to everyone who contributed, especially for taking the time to make the recording.
If I make any further observations or discoveries, I’ll be sure to share the results here as well. Hopefully this thread will be useful to other Rocket owners who notice the same thing in the future!
I week also say mine made plenty of odd sounds in the lower rpms when new. Virtually all stopped after getting the ECU tuned.
ECU tuning is actually on my list of things to try as well. I'm curious to see whether it makes a difference with these sounds on mine too.
