REAR BRAKE LIGHT SWITCH
DCRocket
Chicago
Has anyone replaced one of these? or know what's involved?
Thought I'd get some info from you guys in the know before I dive in.
Symptom: as I push down rear brake pedal the brake light gets brighter.
Thanks,
No takers, huh?
I think I'll start by adjusting the rear brake free play and see if that helps
No takers, huh?
Hmmm, maybe change out that dark side tire. [emoji56]
Just kidding of course. I thought that was just a N/O switch - on or off. I totally don't get it acting like a variable voltage. Disconnect the switch and jumper the connector to see if it acts normal. Process of elimination in the absence of any experience from our esteemed brethren.
This is a new one on me! So what happened, the switch wore out through the first part of its travel?
It could also be the switch is not making good contact at the beginning of travel (wear). Replacing it with a new unit should fix that problem. You might also douse the switch assembly with WD-40 to clean the contact surfaces and see if it improves the behavior.
