Gateway77
Hi
After disconnecting the battery to fit some Optimizer cables - I noticed that the quick shifter was no longer working.
After talking to the local tech guys they gave me the following instructions
1. Turn on Bike
2. Go to Home Menu > Bike Setting
3. Enable TSA
4. Turn off bike.
5. Turn on bike - go for a ride but DO NOT use quick shift.
6. You must go through each gear for 10 secs to allow the system to relearn the gears.
Following this procedure - everything worked perfectly.
If this tip has already been added somewhere else, apologies for repeating.
For me I think the quick shift on this bike is superb - highly recommended.
NB: I have a Triple Black GT - but my gear select pedal isn't black - just standard alloy colour.
I have a black pedal but it just came with the paperwork as a separate item.
The dealer told me that the black pedal won't work with the quick shifter and I should leave the standard item on (not try to replace).
Can anyone else confirm thats correct - seems strange as I'm sure it's the same part just black or alloy?
1. Turn on Bike
3. Enable TSA
4. Turn off bike.
