nope, you should be all good, most folks bump it to between 900-950 range. helps with oil pressure and on mine it seems to shift better into the lower gears when stuck in traffic...
If that still does not raise it enough utilize the tolerances on the TPS sett. By this I mean set it to .62 instead of .6 also when you check the stepper motor it will still raise by .12 but will read .74 volts.
Change the idle rpm values as Dave stated above and if it is not enough for you then you set the primary TPS at .62 and check the steper motor to make sure it moves to .74 which is the .12 normal movement plus the .02 tolerance oringinally used up in setting the primary TPS
