propeller shaft - Attention!!
Raketenpeter
......rollin' like it's stolen......
Vienna - Austria
Rocket 3 Roadster "Blue Haze" - 2011
Hello ! advice to all !
In our Forum here in Europe we discuss a big Problem with the propellershaft. If you change the rear tire it is important to check the "connection from the propellershaft to the rear wheel" it is simply there are only 4 screws ! in some (older?) bikes it is completly dry and rusty see the Pictures as Attachment !
Greetings from Vienna Peter !
OK, thank you, but this is, according Triumph, maintenence-free !! And much biker and dealer dont think abaut this to control..... On my Rocket (2011) i check this one Month ago and it was OK ! (see Pictures as attachment) greetings Peter!
looks like moisture might have "leaked" in.
HONDA Moly Lube 60
Isn't a lack of grease on those splines responsible for them binding and shearing off?
Hello Peter. This is an old subject that has been discussed on this and other forums many times. The answer is to lube the splines with grease with a minimum moly content of 60% at every tire change.
Hello Streetcriuser ! Ahhh OK sorry! I dont know this so we will finished the thread now ! Greetings from the cold Vienna ! Peter
