Navigator
Midroc said:Forgive my ignorance, but what is it? :?: :?: :?:
Thanks...I didn't want to ask. I figured I'd be the only one who didn't know...
140cubicinches said:I'm only a truck driver but ....... :shock: ..Look what found :shock:
Those reading were taking inside my garage in the morning at room temperature 74 f
On the right my oil deep stick thermometer very accurate at 74 f
on the left an ODB II Monitorind device http://www.r3owners.com/viewtopic.php?p ... ht=#188911
it read the same input triumph reads on there computer
ALL of them should read 74 fahrenheit.... NO :shock:
I found out that the 2 sensor AIT for air intake temp. is off 4 degree fahrenheit
and the wather temp. is off by 10 degree fahrenheit
That meen .........the fan start at 217 fahrenheit or 103 celcius triumph specs.
but in fact the cooland is only at 207 fahrenheit or 97 celcius when the fan start
that why the fan blower is always on in trafic because it receiving bad input from the cooland sensor
The fan is on thinking it's hot but in fact it's not that hot 10 fahrenheit or 6 celcuis off
the thermostat is doing is job by keeping the engine hot 185 fahrenheit or 85 celcius on the road at 60 fahrenheit or 15 celcius out side temp. @ 65mph
but the cooland sensor read (wrong input) 195 fahrenheit or 90 celcius
So when the thermostat is not working properly like mind does
at 60 fahrenheit or 15 celcius out side temp. @ 65mph is doing 185 fahrenheit or 85 celcius but when it's hotter
let see 80 fahrenheit or 27 celcius out side temp.my engine temp. rize to 205 fahrenheit or 96 celcius it's hot realy hot
but in fact it thinks (wrong input) it's running at 215 fahrenheit or 101 celcius
thats why the fan starts right away when we stop and now we're looking like a big live BBQ
do the math 20 degrees more on the thermostat
less 10 degrees off wrong input = no threshold
So far only ozdave can corroborate what i'm saying he's got the same OBD II PLX Device instal on his ROCKET III touring
he has to check is PLX device reading and compare it with a room temp. thermometre
The next step is to convince triumph about this :shock:
Ol Skool said:Do you think a few degrees one way or another is going to matter? The ECU reads the voltage inputs from the sensors, could the problem be in the conversion of those voltages in the units you have hooked up to the bike?
140ci- I think the ambient baro pressure sensor takes readings on start up only.
