I will attach a picture of an oil leak I have, what fix would you recommend. It is at the rear of the engine, it looks like it has electrical wires coming from it.
That is the crank sensor ,if you remove the bolt it will pull out (a little oil will come out but should be next to nothing) there is an O ring that forms the seal maybe perished or nicked when assembled last easy fix remove old one replace with new one a dab of oil to help it, and while you have it out clean any metal filings of the end as this can effect the bikes tick over.
hope this helps,
charlie
