Learn
PRESSURE RATIO if you intend to race your supercharged R3:
In determining pressure ratio, the absolute pressure at the compressor inlet (P1c)  is often LESS than the ambient pressure, especially at high load. Why? Any restriction (caused by the air filter or restrictive  ducting) will result in a “depression,” or pressure loss, upstream of  the compressor that needs to be accounted for when determining pressure  ratio. This depression can be 1 psi or more on some intake systems. Direct measurement of P1c is always best (but must be recorded under actual conditions).
Where:
·                               P1c = Compressor Inlet Pressure (psi)
·                               Pamb = Ambient Air pressure (psi)
·                               ΔPloss = Pressure Loss due to Air Filter/Piping (psi)
Next, determine the compressor discharge pressure (P2c). This is also best done by direct measurement. On restrictive intake setups the pressure drop can be 4 psi or  greater (like TTS 180 degree intercooler-plumbing nightmare).
Where:
· P2c = Compressor Discharge Pressure (psi)
·                               MAP = Manifold Absolute Pressure (psi)
·                               ΔPloss = Pressure Loss Between the Compressor and the Manifold (psi)
Now we can calculate Pressure Ratio () using the equation:
Why would this be important for racing? Would  change greatly if                               P1c changed slightly? Does your supercharged R3 air intake pressurize over 160 MPH? Mine certainly does.
