New Bowden cable service from Burchard Excellence
Ishrub
2x2010 ABS Roadsters, Sprint ST 1050 ABS, 3x250s
People have ordered custom cables from a well known US supplier Barnett for years but if it ever drys up or you are in Europe whatever here is another. Apparently our R3 cable connections are a little unusual too, restricting cable makers with the right components.
Burchard have been a high end custom motorcycle parts design and supply operation for many years including Triumph R3s since the Noughties.
Dear Ladies and Gentlemen
we would like to introduce our new Bowden cable service. From now on we can produce all common Bowden cables, such as throttle, idle cables, clutch cables and choke cables according to sample in your desired length.
How does this work?
Quite simply: You select the desired Bowden cable service on our website (see below), such as "Throttle cable extension opener (A) individually coated to desired dimension Stahlflex according to your specifications". Then enter your desired allowance under the field "Comment on item:", e.g. 11cm and place the item in the shopping cart. Next, you can order the item in the store as usual. Now you only have to send us your original Bowden cable. We will take over the original connections of the old cables in case of special cables and otherwise make a completely new cable. The processing time is about 2-3 days after receipt of your Bowden cable.
In addition, we will add some completely configurable Bowden cables in the next weeks, so that you would not always have to send in your Bowden cables in the future (only available for common models). The Bowden cables will then be listed under the vehicle types, as is already the case for the Yamaha XV 750 - 1100 Virago models, for example.
Do you have any questions about our service? Then we are available to you as usual by e-mail or telephone.
Your Motorrad Burchard Team
Throttle Cable (A) extension steel braided individually on request size according to your specifications​
Clutch Cable extension steel braided individually on request size according to your specifications​
