RockOn
Turbocharged
- Joined
- Feb 22, 2018
- Messages
- 585
- Location
- Escondido, CA
- Ride
- 2006 R3 Classic, 2008 R3T, 2009 Harley Ultra
Going down I15 South on Expressway at 75 mph in 5th when suddenly had no thrust. First thought was transmission slipped out of gear and into neutral, downshifted looking for a gear and found nothing giving me forward motion, thumbed on turn signals and they did not work, managed to get over onto right shoulder and rolling to a stop when my gauges started sweeping and all the idiot lights appeared to come on as if I just turned the ignition on.....I shifted into first and had forward thrust again.
Having a quiet helmet, loud traffic whizzing by on both sides of me at 70-80 mph and a very quiet exhaust I can't be sure if the engine ever died during this event but twisting the throttle did not produce any power and it felt like the engine had quit. It seems to me I would have heard and/or felt the engine revving if it were still running as I tried to find a working gear. Then the gauge lights all coming on briefly and needles sweeping appears to be the ignition turning on as if I had just switched on the ignition from the off position seems to confirm that both the electrics and engine had quit and then was running again when electrical power was restored. I am assuming the engine can restart without needing me to engage the starter......like you can when push starting a car. All of this occurred within 10 seconds or so.
If my observations are accurate what might cause the ignition to turn off and then on again? I'm certain I did not turn the kill switch off and then on again. I replaced the ignition switch about 6 months ago with Decosse's keyless unit. Also replaced the regulator/rectifier with the Suzuki unit several months ago.
Faulty main fuse? Faulty brain? Faulty relay? Faulty kill switch? ??? Thanks for any suggestions.
